[Qgis-user] z factor
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Tue Dec 1 15:51:12 PST 2020
Hi David,
Thanks. Found this in my trash. Sorry for not responding sooner. I
will look at the snippet It will be handy. So far, I have been using
the plugin Builder and this
https://www.qgistutorials.com/en/docs/3/building_a_python_plugin.html
It's not up to date but it gives me a good idea of the procedure. I put
the project aside this week but will probably get back to it next week.
I have never programed a GUI before so that is my biggest issues for
now. I should figure it out.
Thanks again,
Nicolas
On 2020-11-27 4:04 p.m., David Strip wrote:
> And let us know how your experiment goes. I've thought about writing a
> plug-in, but never had a motivating problem. I did finally write a
> small snippet of code to add a new item to the file menu. The docs
> served well for the most part.
> Attached file will add new File menu item to copy selected features
> from the current layer to a new memory layer.
> On Windows place this in C:\Users\<your
> account>\AppData\Roaming\QGIS\QGIS3
> Presumably there's an obvious similar place on Macs and Linux.
> If you can, help others; if you cannot do that, at least do not harm
> them.
> /Dalai Lama/
Nicolas Cadieux
https://gitlab.com/njacadieux
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201201/b279435e/attachment.html>
