[Qgis-user] R: R: Importing a raster into a Geopackage
Alberto Vavassori
alberto.vavassori at polimi.it
Wed Dec 2 08:29:39 PST 2020
Hi Nicolas,
yes, you can share the question. Let me know.
Thankyou.
Alberto
Da: Nicolas Cadieux <njacadieux.gitlab at gmail.com>
Inviato: mercoledì 2 dicembre 2020 17:11
A: Alberto Vavassori <alberto.vavassori at polimi.it>
Cc: Kirk Schmidt <kirk at nortekresources.com>; qgis-user at lists.osgeo.org
Oggetto: Re: [Qgis-user] R: Importing a raster into a Geopackage
Hi Alberto,
Can I share the file and your question in the gdal dev group? Perhaps they will have an answer to your problem. You can also do that yourself if you prefer.
Kirt, if you have time, can you do the same run with the data in my google link? If you can’t duplicate the problem, then we will have a better idea if you share your QGIS version and OS. Perhaps there is change in the gdal version between both computers.
Nicolas Cadieux
https://gitlab.com/njacadieux
Le 2 déc. 2020 à 10:11, Alberto Vavassori <alberto.vavassori at polimi.it<mailto:alberto.vavassori at polimi.it>> a écrit :
Hi Kirk,
I tried with another raster file that represents a temperature distribution (continuous values). In this case, when I import it into the Geopackage, I see the same issue that you have just described: minimum and maximum values in the legend change, but it seems that the actual values remain unchanged, thus correct. Unfortunately this is not the case of the land cover raster (discrete set of values) that I have shared with you: in this case, the raster characteristics change, as we have all noticed.
Just another question, hoping that you might have an answer: is it possible to store the symbology of a raster file inside the Geopackage? I know that it is possible for vector data, by clicking on “Style > Save style” in the “Symbology” tab. But I cannot find a way to save the symbology in case of raster files.
Thanks a lot.
Alberto
Da: Qgis-user <qgis-user-bounces at lists.osgeo.org<mailto:qgis-user-bounces at lists.osgeo.org>> Per conto di Kirk Schmidt
Inviato: mercoledì 2 dicembre 2020 16:00
A: Nicolas Cadieux <njacadieux.gitlab at gmail.com<mailto:njacadieux.gitlab at gmail.com>>; qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
Hi all:
I ran the r.stats to get a list of each pixel value on my test data (A small DEM) before and after conversion to a geopackage (see second image below). The values and summary stats are identical for the two rasters but the default legend entry has a different min and maximum value. So, I can conclude that the data is being written correctly but the default display parameters for the geopackage are different than a geotiff.
Kirk
<image001.png>
<image002.png>
On 12/1/2020 3:24 PM, Nicolas Cadieux wrote:
I changed the link so you have access to more files.
https://drive.google.com/drive/folders/1fMl9odowUFFRQFK61rTxgHeom_D8ymN6?usp=sharing
Nicolas
On 2020-12-01 1:58 p.m., Kirk Schmidt wrote:
Hi Nicolas
I did the same and the legend indicates a change magnitude but if I subtract the geopackage raster from the original, all pixels equal zero.
Kirk
On 12/1/2020 2:36 PM, Nicolas Cadieux wrote:
Tried this:
gdal_translate -of GPKG -b 1 C:/Users/Nicolas/Desktop/Land_cover_Corine2018.tif C:/Users/Nicolas/Desktop/test.gpkg
I read 4 band and still get data modifications.
Nicolas
On 2020-12-01 1:28 p.m., Kirk Schmidt wrote:
Hi Nicolas:
try the -b 1 parameter. I just tried this and wrote a single band raster from a 3 channel tiff.
Kirk
On 12/1/2020 2:03 PM, Nicolas Cadieux wrote:
I tried
gdal_translate -of GPKG -co "BAND_COUNT=1" C:/Users/Nicolas/Desktop/Land_cover_Corine2018.tif C:/Users/Nicolas/Desktop/TEST.gpkg for the creation and
C:\>gdal_translate -of GPKG -co "TILE_FORMAT = TIFF" C:/Users/Nicolas/Desktop/Land_cover_Corine2018.tif C:/Users/Nicolas/Desktop/TEST.gpkg
Same problem. I wonder if we need to change the reading options... https://gdal.org/drivers/raster/gpkg.html
"Opening options
By default, the driver will expose a GeoPackage dataset as a four band (Red,Green, Blue,Alpha) dataset, which gives the maximum compatibility with the various encodings of tiles that can be stored. It is possible to specify an explicit number of bands with the BAND_COUNT opening option."
The problem could be when QGIS Reads the file, not when it writes the file. I explains why we see 4 bands but not why values are changing. I would make a bug report or ask the question on the gdal dev group to get Even Rouault's attention.
Nicolas
On 2020-12-01 12:17 p.m., Sebastian Gutwein wrote:
This looks like the same issue you are having. github.com/qgis/QGIS/issues/38227<http://github.com/qgis/QGIS/issues/38227>
According to the documentation linked in the issue you need to set the band count to 1 otherwise it defaults to 4.
gdal.org/drivers/raster/gpkg.html<http://gdal.org/drivers/raster/gpkg.html>
I have not tried this to see if it works.
On Tue, Dec 1, 2020 at 11:52 AM Nicolas Cadieux <njacadieux.gitlab at gmail.com<mailto:njacadieux.gitlab at gmail.com>> wrote:
Looking at it now. I see what you see. I will try a few things.
Nicolas
On 2020-12-01 11:42 a.m., Alberto Vavassori wrote:
Hi Nicolas,
thank you for the answer. I send the raster that I am interested in.
Alberto
Da: Nicolas Cadieux <njacadieux.gitlab at gmail.com><mailto:njacadieux.gitlab at gmail.com>
Inviato: martedì 1 dicembre 2020 17:40
A: Alberto Vavassori <alberto.vavassori at polimi.it><mailto:alberto.vavassori at polimi.it>
Cc: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
Oggetto: Re: [Qgis-user] Importing a raster into a Geopackage
Send a sample data set if you can't figure it out.
Nicolas
On 2020-12-01 10:35 a.m., Nicolas Cadieux wrote:
Perhaps this can help: https://gdal.orgdrivers/raster/gpkg.html
“Various kind of input datasets can be converted to GeoPackage raster :
· Single band grey level
· Single band with R,G,B or R,G,B,A color table
· Two bands: first band with grey level, second band with alpha channel
· Three bands: Red, Green, Blue
· Four band: Red, Green, Blue, Alpha
GeoPackage rasters only support Byte data type.”
My guess is that if the original raster does not correspond to one of the categories above, it will be converted to the closest format.
Nicolas Cadieux
Le 1 déc. 2020 à 09:58, Alberto Vavassori <alberto.vavassori at polimi.it><mailto:alberto.vavassori at polimi.it> a écrit :
Hello everybody. I have an issue regarding the Geopackage format. I have tried to import a singleband raster file (it represents the land cover, thus every pixel has a single integer value corresponding to the land cover class), but this operation seems to modify the raster characteristics: the raster becomes a 4-bands raster and the pixels values change accordingly (basically, the original raster is saved in the Geopackage as an RGB image). It seems to be a bug of QGIS. I have also tried to use GDAL translate through the processing toolbox of QGIS to convert the TIFF file to a Geopackage file, but the result is the same.
Has anybody faced this problem? May anybody suggest a way to work this problem out?
Thank you.
Alberto
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Nicolas Cadieux
Nicolas Cadieux
Nicolas Cadieux
Kirk Schmidt, MScF, BScF, RPF
General Manager
Nortek Resource Solutions Inc.
RR # 1
Thorburn, NS
B0K 1W0
Tel (902) 922.3607
Email: kirk at nortekresources.com<mailto:kirk at nortekresources.com>
Web: www.nortekresources.com<http://www.nortekresources.com>
Nicolas Cadieux
General Manager
RR # 1
Thorburn, NS
B0K 1W0
Tel (902) 922.3607
Nicolas Cadieux
General Manager
RR # 1
Thorburn, NS
B0K 1W0
Tel (902) 922.3607
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201202/6a353025/attachment-0001.html>
