[Qgis-user] QGIS 3.16 Installation on Linux Mint
Alexandre Neto senhor.neto at gmail.com
Sat Dec 5 12:42:54 PST 2020
Why don't you follow this instructions:
https://www.qgis.org/en/site/forusers/alldownloads.html#quickstart
A sábado, 5/12/2020, 14:11, Mike Flannigan <mflan at mflan.com> escreveu:
> Thanks for this information.
> I wish I could execute the 3.16.1 QGIS that Synaptic thinks I have.
> I will probably uninstall via Synaptic and try to reinstall.
> Mike
> On 12/4/20 7:03 PM, Roderick Anderson wrote:
> > No Flatpak expert here but I'd guess the version (executable)
> > installed using flatpak falls lower in the path than the regular
> > package manager does.
> >> Synaptic package manager says I have 3.16 installed:
> >> http://www.mflan.com/temp/synaptic.jpg
> >> but I have looked hard and can't find it.
> >> 'sudo apt-get purge QGIS' does not get rid of 3.16.
> >> Software Manager says I have 3.10 Flatpak installed, but
> >> not the regular 3.16.1+28bionic that is also listed in
> >> the Software Manager.  If I try to install 3.16.1+28bionic
> >> it fails immediately on package dependency problems.
> > I had tried installing using Synaptic and got 2.16 so I uninstalled it
> > and used Flatpac.  Just checked and see 2.18 offered via the package
> > manager.
> >> So my system keeps updating, but I am left with only 3.10 to run.
> >> Perhaps Flatpak 3.16 will come along eventually.  Or maybe
> >> I will uninstall 3.16 from Synaptic package manager and then
> >> try to reinstall 3.16 from Software Manager or from the
> >> QGIS website.
> >> If I did the Flatpak on this site
> >> https://www.qgis.org/en/site/forusers/alldownloads.html#flatpak
> >> what version would I get?
> > I got 3.16.1-Hannover using the instructions.
> > Here is my menu command line
> > /usr/bin/flatpak run --branch=stable --arch=x86_64 --command=qgis
> > --file-forwarding org.qgis.qgis @@ %F @@
> > Good luck,
> > Rod
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201205/29e7cd0f/attachment.html>
