[Qgis-user] QGIS 3.16 Installation on Linux Mint
Andrea Giudiceandrea
andreaerdna at libero.it
Sat Dec 5 13:16:25 PST 2020
Alexandre Neto wrote
> Why don't you follow this instructions:
> https://www.qgis.org/en/site/forusers/alldownloads.html#quickstart
Hi Alexandre,
the command
sudo add-apt-repository "deb https://qgis.org/debian `lsb_release -c -s`
main"
does not work correctly on Linux Mint, because lsb_release -c -s returns the
Linux Mint codename (e.g. ulyana, tricya, ...) instead of the corresponding
Ubuntu codename (e.g. focal, bionic, ...).
On Linux Mint the following command could be used in order to add the right
repository:
sudo add-apt-repository "deb https://qgis.org/debian $(. /etc/os-release;
echo "$UBUNTU_CODENAME") main"
Moreover, it seems QGIS 3.16 is yet installed in Mike's Linux Mint system,
but he cannot find the correct launcher. Probably the launcher was
overwritten by the installation of the Flatpak version of QGIS. In this
case, he only needs to create another launcher.
Regards.
Andrea
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
