[Qgis-user] QGIS 3.16 Installation on Linux Mint
Mike Flannigan
mflan at mflan.com
Sat Dec 5 14:32:40 PST 2020
Those instructions are what brought up this issue.
Apparently
sudo add-apt-repository "deb https://qgis.org/debian `lsb_release -c -s`
main"
is good for Ubuntu, but not Linux Mint. For LM use this instead:
sudo add-apt-repository "deb https://qgis.org/debian bionic main"
Right now I am using QGIS quite a bit and I can't do with out.
When I get a break I will try to get the QGGIS version 3.16
on the LM Software Manager to install. If that doesn't work I
will follow the QuickStart procedure modified to bionic.
I have used those QuickStart procedures successfully in the past.
Mike
On 12/5/20 2:42 PM, Alexandre Neto wrote:
> Why don't you follow this instructions:
> https://www.qgis.org/en/site/forusers/alldownloads.html#quickstart
> A sábado, 5/12/2020, 14:11, Mike Flannigan <mflan at mflan.com
> <mailto:mflan at mflan.com>> escreveu:
> Thanks for this information.
> I wish I could execute the 3.16.1 QGIS that Synaptic thinks I have.
> I will probably uninstall via Synaptic and try to reinstall.
> Mike
> On 12/4/20 7:03 PM, Roderick Anderson wrote:
> > No Flatpak expert here but I'd guess the version (executable)
> > installed using flatpak falls lower in the path than the regular
> > package manager does.
> >> Synaptic package manager says I have 3.16 installed:
> >> http://www.mflan.com/temp/synaptic.jpg
> >> but I have looked hard and can't find it.
> >> 'sudo apt-get purge QGIS' does not get rid of 3.16.
> >> Software Manager says I have 3.10 Flatpak installed, but
> >> not the regular 3.16.1+28bionic that is also listed in
> >> the Software Manager. If I try to install 3.16.1+28bionic
> >> it fails immediately on package dependency problems.
> > I had tried installing using Synaptic and got 2.16 so I
> uninstalled it
> > and used Flatpac. Just checked and see 2.18 offered via the
> package
> > manager.
> >> So my system keeps updating, but I am left with only 3.10 to run.
> >> Perhaps Flatpak 3.16 will come along eventually. Or maybe
> >> I will uninstall 3.16 from Synaptic package manager and then
> >> try to reinstall 3.16 from Software Manager or from the
> >> QGIS website.
> >> If I did the Flatpak on this site
> >> https://www.qgis.org/en/site/forusers/alldownloads.html#flatpak
> >> what version would I get?
> > I got 3.16.1-Hannover using the instructions.
> > Here is my menu command line
> > /usr/bin/flatpak run --branch=stable --arch=x86_64 --command=qgis
> > --file-forwarding org.qgis.qgis @@ %F @@
> > Good luck,
> > Rod
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201205/41c03b5b/attachment.html>
