[Qgis-user] transfer single points from one point-layer to another?
Andreas Neumann
andreas at qgis.org
Mon Dec 7 05:51:49 PST 2020
Hi Stef,
Yes, possible. But: data is independent of project. So you basically copy
data from one database or file to another one - regardless of the projects
referencing these data sources. So other projects linking to the same
database or file will also see the updates.
[image: grafik.png]
First, select objects in one layer, then press "copy", then make the other
layer active and press "paste".
Andreas
On Mon, 7 Dec 2020 at 12:43, ent-artet at gmx.de <ent-artet at gmx.de> wrote:
> Hello list :-)
> is it possible to transfer a certain amount of points from one project
> to another?
> Together with all the informations?
> Many regards,
> Stef
> Qgis-user mailing list
Andreas Neumann
QGIS.ORG board member (treasurer)
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201207/430f8126/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201207/430f8126/attachment.png>
