[Qgis-user] transfer single points from one point-layer to another?
Nicolas Cadieux njacadieux.gitlab at gmail.com
Mon Dec 7 06:39:04 PST 2020
Regular Cut and paste crtl-c and crtl-v shortcuts work. Don’t forget to  make sure the “receiving” layer is in editing mode (yellow pen). You must select that layer, and then select the yellow button and that this layer is editable like a .shp or like a geopackage. (Ex: A csv can be read but not written to.). Data will follow if the database match perfectly.  If not, you may have missing data  (unless this has been changed.)
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 7 déc. 2020 à 08:52, Andreas Neumann <andreas at qgis.org> a écrit :
> Hi Stef,
> Yes, possible. But: data is independent of project. So you basically copy data from one database or file to another one - regardless of the projects referencing these data sources. So other projects linking to the same database or file will also see the updates.
> First, select objects in one layer, then press "copy", then make the other layer active and press "paste".
> Andreas
>> On Mon, 7 Dec 2020 at 12:43, ent-artet at gmx.de <ent-artet at gmx.de> wrote:
>> Hello list :-)
>> is it possible to transfer a certain amount of points from one project
>> to another?
>> Together with all the informations?
>> Many regards,
>> Stef
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Andreas Neumann
> QGIS.ORG board member (treasurer)
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201207/72730095/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201207/72730095/attachment-0001.png>
