[Qgis-user] QGIS really slow with .gpkg layers
Alessandro Pasotti apasotti at gmail.com
Thu Dec 10 06:59:41 PST 2020
On Thu, Dec 10, 2020 at 3:41 PM Francesco Pelullo <f.pelullo at gmail.com> wrote:
> Hi all,
> I'm running QGIS 3.10 LTR on Windows 10.
> My project has 6 .gpkg files connected, everyone of these has 14 layers with points geometries, every layer counts about 16.000 features.
> So my QGIS project manage about 1.344.000 points, not used at same time.
> When i open this project, QGIS needs about 15 minutes for go ready.
> Instead, if i store these points in separate .TXT files, QGIS needs only few seconds for load layers and go ready. Also .shp layer format seems more performant than .gpkg
> It seems to me that they are not really efficient for these points layers.
> Is this a my problem? Or there are some tricks i could use?
if you can share your project and data we can check if it also happens
on other machines or if it is a local issue.
But first you should also check if the issue is still valid with QGIS 3.16.
Regards
Alessandro Pasotti
QCooperative:  www.qcooperative.net
ItOpen:   www.itopen.it
