[Qgis-user] QGIS really slow with .gpkg layers
Árni Geirsson arni at alta.is
Thu Dec 10 07:08:47 PST 2020
Hi  Francesco
In my experience, QGIS reads gepackages very slowly if they are on a shared
drive (NAS/SMB). I have to make them read-only to get decent performance.
Árni Geirsson
*Alta ehf* // +354 582 5003 // +354 897 9549
On Thu, 10 Dec 2020 at 14:59, Alessandro Pasotti <apasotti at gmail.com> wrote:
> On Thu, Dec 10, 2020 at 3:41 PM Francesco Pelullo <f.pelullo at gmail.com>
> wrote:
> > Hi all,
> > I'm running QGIS 3.10 LTR on Windows 10.
> > My project has 6 .gpkg files connected, everyone of these has 14 layers
> with points geometries, every layer counts about 16.000 features.
> > So my QGIS project manage about 1.344.000 points, not used at same time.
> > When i open this project, QGIS needs about 15 minutes for go ready.
> > Instead, if i store these points in separate .TXT files, QGIS needs only
> few seconds for load layers and go ready. Also .shp layer format seems more
> performant than .gpkg
> > It seems to me that they are not really efficient for these points
> layers.
> > Is this a my problem? Or there are some tricks i could use?
> Hi,
> if you can share your project and data we can check if it also happens
> on other machines or if it is a local issue.
> But first you should also check if the issue is still valid with QGIS 3.16.
> Regards
> Alessandro Pasotti
> QCooperative:  www.qcooperative.net
> ItOpen:   www.itopen.it
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201210/0478f286/attachment.html>
