[Qgis-user] Unable to import name NUMPY_MKL for Scipy Point Clustering Plugin
Nicolas Cadieux njacadieux.gitlab at gmail.com
Sun Dec 20 18:14:52 PST 2020
Problem could be related to this post: https://issues.qgis.org/issues/21161
It has no solution then to downgrade the python-scipy library from
0.19.0-1 to 0.14.0-1.  The post ends with the bottom line that Qgis 2.18
in no longer supported...
This post may have more info.
https://stackoverflow.com/questions/37267399/importerror-cannot-import-name-numpy-mkl
"This problem can be easy solved by installation for numpy+mkl from whl
file from here <http://www.lfd.uci.edu/~gohlke/pythonlibs/#numpy>."
(https://www.lfd.uci.edu/~gohlke/pythonlibs/#numpy)
To install a whl, I would look at this.
https://pip.pypa.io/en/latest/user_guide/#installing-from-wheels
The python 2.7 distribution should be somewhere in the directory with QGIS.
I think the best would be to install a new supported version of QGIS and
then find a plugin that does what you need. (perhaps
https://plugins.qgis.org/plugins/clusterpoints/ ???) Your work should
upgrade to
Version 3.10.12 LTR
Good luck
Anybody else got an idea?
Nicolas
On 2020-12-20 11:26 a.m., krishna Ayyala wrote:
> Hello friends,
> My work requires me to use QGIS 2.18.x. Hence, I downloaded
> QGIS2.18.28. I am trying to install "Scipy Point Clustering" plugin.
> Can you please help me on how to import NUMPY_MKL?
> Regards.
> Qgis-user mailing list
Nicolas Cadieux
https://gitlab.com/njacadieux
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201220/e25a78a7/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201220/e25a78a7/attachment-0001.png>
