[Qgis-user] QGIS 3.xx not starting
K R Mayani krmayani.procivil at gmail.com
Wed Dec 23 00:29:05 PST 2020
Thanks for the guidance from users, Nicolas Cadieux  and Ujaval Gandhi.
I have tried with disabled QuickHeal first, but no success. Then doing some
other that was uninstalling the antivirus software. then QGIS was started.
(As I have licensed version of QHeal, I wanted to have it on my system). So
here is what I have done finally and till now QGIS starts and performs. I
hope you can suggest below steps to others who have this issue if you came
into contact with them.
-> Uninstalled Qheal first. Restarted the system.
->  Installed QGIS with windows defender "off" and real time scan "off".
QGIS was able to start.
-> After installation, In the win-defender there is a option of "exclude
folder", there I had selected the QGIS installed directory folder.
-> Then, as I have mentioned licensed QHeal, I again installed Qheal and
again I have added some exe's of QGIS,Python,QT, .
-> After that, by taking god's name, I have started QGIS. and VOILA. It is
now functioning.
Lastly, I want to thank you for valuable suggestions and from that I was
able to start my QGIS v3.10, the stable one.
Thanks for the help.
On Mon, Dec 21, 2020 at 9:19 PM Nicolas Cadieux <njacadieux.gitlab at gmail.com>
wrote:
> Hi,
> I would start with the suggestion below.  Then, I would update all the
> drivers and try to see what other software is normally auto loaded at
> startup to see what could be interfering with QGIS (like a anti malware).
> Concerning Quickheal, it may have blocked something at the installation so
> I would uninstall it (or disable it completely) and uninstall  QGIS.
> Reboot, then reinstall QGIS.
> Nicolas Cadieux
> https://gitlab.com/njacadieux
> Le 21 déc. 2020 à 00:35, Ujaval Gandhi <ujaval at spatialthoughts.com> a
> écrit :
> One of the original suggestions was to disable / uninstall your anti-virus
> and try launching qgis. Did you try that? From your description it looks
> like Quickheal might be interfering with qgis. Qgis has other dependencies
> on python, qt etc so merely allowing qgis may not be enough.
> Ujaval Gandhi
> Spatial Thoughts
> On Mon, Dec 21, 2020, 9:41 AM K R Mayani <krmayani.procivil at gmail.com>
> wrote:
>> As one suggestion came from other source, I have tried opening QGIS with
>> firewall off. So I tried to add .exes of python, qgis ltr, qgis in allowed
>> program in QuickHeal, as its installed and managed firewall, but did not
>> start.
>> So that strike me another idea. And I started the program in safe boot
>> mode with network  in windows 10. Surprisingly the program ran normally
>> without crashing.
>> So can anyone give me any idea, what went wrong in normal boot mode?
>> Because in safe boot, OS does not allow to connect through wifi and I, had
>> to, mostly work with wifi.
>> On Tue, Dec 8, 2020, 7:32 PM Nicolas Cadieux <njacadieux.gitlab at gmail.com>
>> wrote:
>>> Hi,
>>> Just a bunch of ideas...
>>> Did you have a working version before or is this a first time QGIS
>>> installation?  You have 2 choices of installers on Windows, I would try
>>> with the second installer after removing the first version.  Reboot the
>>> computer after the installation.  Try Disabling your antivirus or adware
>>> software you could have when installing or starting QGIS, make sure your
>>> Windows and drivers are up to date.  Do you have a second version of Python
>>> on your computer, or a software like ESRI that as it’s own version of
>>> Python? Perhaps there is a conflict between your QGIS python and the
>>> default python distribution?  If this is not a new install, would you have
>>> a problématique python plugin  in the plugin directory? Perhaps try
>>> removing those...  Would you have weird character in your user directory
>>> like spaces or accents like “é”?
>>> Nicolas Cadieux
>>> Le 8 déc. 2020 à 07:07, K R Mayani <krmayani.procivil at gmail.com> a
>>> écrit :
>>> Hi,
>>> I am using QGIS 3.14.1 on my Laptop. I am having trouble with the
>>> software about its starting. After setting up python screen, it does not
>>> starts. I have also tried "run as administrator" but still the problem
>>> persists. With v3.10 and v3.14.1, the same problem is there. I have
>>> installed software again with "Run as Administrator" but the issue is not
>>> solved.
>>> .NET 4.8 already installed.
>>> osbuild: 19042.630
>>> OS: Windows 10, home
>>> Processor:AMDRyzen 5 3550H with Radeon Vega Mobile Gfx 2.10 GHz
>>> RAM: 8.00 GB
>>> crash: https://pastebin.com/5Tk75LTu
>>> Which version should support my system rig?
>>> Please help me with my trouble. Or suggest to me the steps.
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201223/a6be7d52/attachment.html>
