[Qgis-user] simple conversion question
Alexandre Neto
senhor.neto at gmail.com
Tue Dec 29 17:29:59 PST 2020
After you project your data into the correct EPSG, you can use the add
geometry attributes processing algorithm to create two new columns for X
and Y.
https://docs.qgis.org/testing/en/docs/user_manual/processing_algs/qgis/vectorgeometry.html#add-geometry-attributes
Basically the same operation described by kirk, but maybe a bit more
straight forward.
Best regards,
Alexandre Neto
A segunda, 28/12/2020, 11:11, kirk <kirk at nortekresources.com> escreveu:
> Hi Cole.
> You need to add the coordinates to your attribute table prior to exporting
> to csv format. First save the data in the correct coordinates system. Open
> the attribute table and add 2 new columns for the x and y coordinates.
> Update each volume using the $x abs $y formula and save the results prior
> to exporting to csv.
> Kirk Schmidt
> Sent from my Samsung Galaxy smartphone.
> -------- Original message --------
> From: Cole Burger <coleburger at protonmail.com>
> Date: 2020-12-28 3:00 a.m. (GMT-04:00)
> To: qgis-user at lists.osgeo.org
> Subject: [Qgis-user] simple conversion question
> Hello,
> First time QGIS user. I'm using 3.16.1-Hannover on macOS Mojave 10.14.6.
> I'm trying to convert latitude/longitude coordinates to EPSG: 2163 US
> National Atlas Equal Area. The coordinates are here:
> https://raw.githubusercontent.com/cpb831/webscraper1/master/institutions%20to%20convert.csv.
> I would like to create a csv file with these coordinates in new
> projection. I followed the steps here:
> https://3drobotics.com/convert-lat-lon-coordinates-into-state-plane-with-qgis/.
> The new csv file just shows the original latitude/longitude coordinates.
> Any additional suggestions?
> Thank you!
> Sent with ProtonMail <https://protonmail.com> Secure Email.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201230/47040215/attachment.html>
