[Qgis-user] [QGIS-Developer] Zoom to Scale Plugin - Should we include it on qgis.org?
Richard Duivenvoorde
rdmailings at duif.net
Thu Feb 20 11:58:32 PST 2020
Hi Chris,
One year ago I proposed the following: a tree embedded widget to be used
for WMS/WMTS layers. It uses the functionality which is in the Juergens
Tile Scale Panel:
http://www.qgis.nl/2019/02/14/about-layer-tree-embedded-widgets-and-have-your-wmts-always-crispy-sharp/?lang=en
Probably you mean something else? As it is not resizing the servertiles,
but 'clicking' to the right scales (coming from the capability
documents) of the active layer.
If you mean plugins.qgis.org when you talk 'adding it to the repo' I
would say yes! Why not?
If you say add it by default to QGIS, I'd say: let's first see and check
it out as plugin :-)
Also (see discussion about resources plugin) adding python plugins to
QGIS installs has some drawbacks.
Regards,
On 2/20/20 8:37 PM, C Hamilton wrote:
> We have written a plugin that fixes the scale of the QGIS canvas to
> match the integral size of EPSG:3857 map server tiles. This way there is
> no degradation of the images by transformation. This has some
> similarities to the QGIS 2 plugin called Tile Map Scale Plugin which was
> never updated for QGIS 3.
> This only works with EPSG:3857 projections. I wish I could figure out a
> way to also match an EPSG:4326 tile cache to the canvas scale size, but
> I cannot use the map scale to calculate this because it changes as you
> move around.
> Would you be interested in having this plugin added into the QGIS repo?
> Unlike the Tile Map Scale Plugin ours only has a single toggle button to
> lock or unlock the QGIS scale to one of the predefined scales.
> Let me know what you think?
> Thanks,
> Calvin
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
