[Qgis-user] [QGIS-Developer] Zoom to Scale Plugin - Should we include it on qgis.org?
Alexander Bruy
alexander.bruy at gmail.com
Thu Feb 20 22:00:08 PST 2020
Also QGIS allows to create custom scale lists and switch between scales
by selecting desired value from the scale combobox in the main window
statusbar.
пт, 21 лют. 2020 о 00:48 Nyall Dawson <nyall.dawson at gmail.com> пише:
> On Fri, 21 Feb 2020 at 05:37, C Hamilton <adenaculture at gmail.com> wrote:
> > We have written a plugin that fixes the scale of the QGIS canvas to match the integral size of EPSG:3857 map server tiles. This way there is no degradation of the images by transformation. This has some similarities to the QGIS 2 plugin called Tile Map Scale Plugin which was never updated for QGIS 3.
> How is this different to the built-in "Tile Scale" panel? Can you clarify?
> Nyall
> > This only works with EPSG:3857 projections. I wish I could figure out a way to also match an EPSG:4326 tile cache to the canvas scale size, but I cannot use the map scale to calculate this because it changes as you move around.
> > Would you be interested in having this plugin added into the QGIS repo? Unlike the Tile Map Scale Plugin ours only has a single toggle button to lock or unlock the QGIS scale to one of the predefined scales.
> > Let me know what you think?
> > Thanks,
> > Calvin
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alexander Bruy
