[Qgis-user] Georeferencing images
Nicolas Cadieux njacadieux.gitlab at gmail.com
Fri Jul 10 07:40:43 PDT 2020
If the images have embedded GPS coordinates, all you need to do is drag and drop the rasters in QGIS.  If you have coordinates but no CRS, you may need to indicate the which Coordinates Reference System to use (Probably WGS84) depending on your settings.  You can install a plugin like quickmap and load a background image.  That will help you figure out if the image are georeferenced correctly.  Look at your coordinates in the lower right corner.  You can use that to figure out if you are in meters or in degrees.
Nicolas Cadieux
Ça va bien aller!
> Le 10 juill. 2020 à 10:22, blubee blubeeme <gurenchan at gmail.com> a écrit :
> Id like to thank the few users who helped me with my previous question.
> It seems like georeferencing will me more work than I initially anticipated.
> Can anyone give me a quick overview of a pipeline to go from uav images with embedded GPS coordinates to a series of stitched maps.
> The area that I'm working on lacks features since it's all mountains with trails that aren't visible from above.
> I could go into certain flat areas and use Garmin device to place makers, that's the most accurate method that I could use to place makers.
> Any tips would be greatly appreciated.
> Best
> Qgis-user mailing list
