[Qgis-user] Georeferencing images
Saber Razmjooei
saber.razmjooei at lutraconsulting.co.uk
Fri Jul 10 10:16:33 PDT 2020
Hi
In the past, we developed a private plugin for georeferencing and
stitching multiple UAV images, similar to ENVI software workflow.
If you are dealing with an area where the elevation changes significantly,
best to follow the discussion here:
https://github.com/qgis/QGIS/pull/36385
As my colleague, Martin suggested, we may need to improve the current
Georeferencer plugin to make use of RPC_DEM.
Kind regards
Saber
On Fri, 10 Jul 2020 at 15:41, Nicolas Cadieux <njacadieux.gitlab at gmail.com>
wrote:
> Hi,
> If the images have embedded GPS coordinates, all you need to do is drag
> and drop the rasters in QGIS. If you have coordinates but no CRS, you may
> need to indicate the which Coordinates Reference System to use (Probably
> WGS84) depending on your settings. You can install a plugin like quickmap
> and load a background image. That will help you figure out if the image
> are georeferenced correctly. Look at your coordinates in the lower right
> corner. You can use that to figure out if you are in meters or in degrees.
> Nicolas Cadieux
> Ça va bien aller!
> > Le 10 juill. 2020 à 10:22, blubee blubeeme <gurenchan at gmail.com> a
> écrit :
> > Id like to thank the few users who helped me with my previous question.
> > It seems like georeferencing will me more work than I initially
> anticipated.
> > Can anyone give me a quick overview of a pipeline to go from uav images
> with embedded GPS coordinates to a series of stitched maps.
> > The area that I'm working on lacks features since it's all mountains
> with trails that aren't visible from above.
> > I could go into certain flat areas and use Garmin device to place
> makers, that's the most accurate method that I could use to place makers.
> > Any tips would be greatly appreciated.
> > Best
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Saber Razmjooei
www.lutraconsulting.co.uk
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200710/49eb0673/attachment.html>
