[Qgis-user] use the new standalone console processing tool, in a server without a GUI
Alexandre Neto
senhor.neto at gmail.com
Tue Jul 14 06:47:47 PDT 2020
You need to install QGIS 3.14 using the standard method for debian, no GUI
is needed for that. Then, after the installation, you will be able to call
qgis_process from the terminal.
Here's some information about qgis_process command line tool while it's
being prepared for the official documentation.
https://github.com/qgis/QGIS-Documentation/issues/5803
Best regards,
Alexandre Neto
QGIS Support
https://www.qcooperative.net
A terça, 14/07/2020, 11:52, aborruso <aborruso at gmail.com> escreveu:
> Hi,
> I have a server without GUI, Debian 11 based.
> Is there a way to install QGIS and use the new standalone console tool for
> running processing algorithms (https://github.com/qgis/QGIS/pull/34617)
> only
> via bash scripts?
> I think yes, but I do not know how to do it.
> Probably I should start from "sudo apt-key adv --keyserver
> keyserver.ubuntu.com --recv-keys 51F523511C7028C3".
> And then add the dev repository, but it would be great to have some step by
> step installation instruction.
> Thank you
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200714/8169027a/attachment.html>
