[Qgis-user] use the new standalone console processing tool, in a server without a GUI
aborruso
aborruso at gmail.com
Tue Jul 14 09:22:00 PDT 2020
Hi Alexandre,
and thank you.
Alexandre Neto wrote
> You need to install QGIS 3.14 using the standard method for debian, no GUI
> is needed for that. Then, after the installation, you will be able to call
> qgis_process from the terminal.
I'm using the standard method
https://www.qgis.org/en/site/forusers/alldownloads.html#debian-ubuntu
If I run `sudo add-apt-repository "deb https://qgis.org/ubuntu
`lsb_release -c -s` main"` and then `sudo apt-get update`, I have `The
repository 'https://qgis.org/ubuntu bullseye Release' does not have a
Release file.`
What's the right way to add the repository? Which dist
(https://qgis.org/ubuntu/dists/) I must use?
Best regards
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
