[Qgis-user] Styling polygon borders: preventing double rendering between polygons
Christoph Jung
jagodki.cj at gmail.com
Thu Jun 11 04:11:00 PDT 2020
Hi Jorge,
If it is just a visual thing, than you could transform your polygons to lines and delete the duplicate geometries.
Sincerely,
Christoph
> Am 11.06.2020 um 12:45 schrieb Jorge Gustavo Rocha <jgr at geomaster.pt>:
> Hi QGisers,
> I'm trying to style a polygon layer (districts) using a marker line (using the '+' sign). It works well for lines.
> When I use it in polygons, the outer line is ok, but the lines between polygons are rendered twice.
> To make this question more clear, I've attached the following print screen: https://nextcloud.geomaster.pt/index.php/s/e3ztdJ894RCf9j6 <https://nextcloud.geomaster.pt/index.php/s/e3ztdJ894RCf9j6>
> The line near the sea is rendered just once. The line going to east between the polygons is rendered twice. We can see double '+' on that line.
> How do I render all the lines exactly the same way, without this "double" rendering between polygons?
> Regards,
> Jorge Gustavo
> <https://www.geomaster.pt/>
> Geomaster
> Jorge Gustavo Rocha | Software Engineer
> e: jgr at geomaster.pt <mailto:jgr at geomaster.pt> | m: +351 910 333 888
> g: 41.54094,-8.40490 | v: 510 906 109
> a: Rua António Cândido Pinto, 67, 4715-400 Braga
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200611/a1e69c7e/attachment.html>
