[Qgis-user] Styling polygon borders: preventing double rendering between polygons
Karl Magnus Jönsson Karl-Magnus.Jonsson at kristianstad.se
Thu Jun 11 04:18:28 PDT 2020
Hi!
I had a similar problem. I’ve made a view ( in PostGIS) to transform the boundaries to lines and remove the duplicate lines. Should be doable in virtual layers as well. Quite complicated SQL since I have several different types of lines depending on the attributes.
Karl-Magnus Jönsson
Från: Qgis-user <qgis-user-bounces at lists.osgeo.org> För Christoph Jung
Skickat: den 11 juni 2020 13:11
Till: Jorge Gustavo Rocha <jgr at geomaster.pt>
Kopia: qgis-user at lists.osgeo.org
Ämne: Re: [Qgis-user] Styling polygon borders: preventing double rendering between polygons
Hi Jorge,
If it is just a visual thing, than you could transform your polygons to lines and delete the duplicate geometries.
Sincerely,
Christoph
Am 11.06.2020 um 12:45 schrieb Jorge Gustavo Rocha <jgr at geomaster.pt<mailto:jgr at geomaster.pt>>:
Hi QGisers,
I'm trying to style a polygon layer (districts) using a marker line (using the '+' sign). It works well for lines.
When I use it in polygons, the outer line is ok, but the lines between polygons are rendered twice.
To make this question more clear, I've attached the following print screen: https://nextcloud.geomaster.pt/index.php/s/e3ztdJ894RCf9j6
The line near the sea is rendered just once. The line going to east between the polygons is rendered twice. We can see double '+'  on that line.
How do I render all the lines exactly the same way, without this "double" rendering between polygons?
Regards,
Jorge Gustavo
[Logo]<https://www.geomaster.pt/>
Geomaster
Jorge Gustavo Rocha | Software Engineer
e: jgr at geomaster.pt<mailto:jgr at geomaster.pt> | m: +351 910 333 888
g: 41.54094,-8.40490 | v: 510 906 109
a: Rua António Cândido Pinto, 67, 4715-400 Braga
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200611/318c8f23/attachment.html>
