[Qgis-user] colorramp starting from white
Anita Graser anitagraser at gmx.at
Mon Jun 15 13:48:25 PDT 2020
15 Jun 2020 15:53:43 Raymond Nijssen <r.nijssen at terglobo.nl>:
> Am I the only one who would like the color ramps in QGIS to NOT start from (super nearly) white, but from a light version of the color?
Quite the contrary. I often have the need to change the starting color to real white or even transparent.
It's probably one of those cases of "it depends!"
In choropleth maps, it's important to distinguish between non and the lowest class. However, for heatmaps and similar viz, a smooth transition from white is often desired.
Conclusion: the starting color should be really easy to change.
Regards
Anita
> For example, "Reds" should go from (light) pink to red.
> Currently, the first class in my legend always looks white, as many other parts of my map often do. Therefore it is hard to see where my data is and where not.
> Another thing, changing it manually is hard because of the 7 stops in the ramps.
> I'm happy to figure this out and make a PR, but would like to know other's opinions first.
> Regards,
> Raymond
> Terglobo
> Fahrenheitstraat 1
> 5223 BJ 's-Hertogenbosch
> The Netherlands
> +31 (0) 6 25 31 49 83
> Qgis-user mailing list
