[Qgis-user] colorramp starting from white
DelazJ delazj at gmail.com
Mon Jun 15 14:06:29 PDT 2020
Trying to quickly change the starting color of a default continuous ramp, I
realize that changing the first color is not enough, you need to
change/remove the intermediate ones also, in order to have something smooth.
So, question: why do we need stops in a color ramp that is supposed to be
continuous from color A to color B? Could the default continuous color
ramps not only have a start color and an end color? Nothing else?
Regards,
Harrissou
Le lun. 15 juin 2020 à 22:48, Anita Graser <anitagraser at gmx.at> a écrit :
> 15 Jun 2020 15:53:43 Raymond Nijssen <r.nijssen at terglobo.nl>:
> > Am I the only one who would like the color ramps in QGIS to NOT start
> from (super nearly) white, but from a light version of the color?
> Quite the contrary. I often have the need to change the starting color to
> real white or even transparent.
> It's probably one of those cases of "it depends!"
> In choropleth maps, it's important to distinguish between non and the
> lowest class. However, for heatmaps and similar viz, a smooth transition
> from white is often desired.
> Conclusion: the starting color should be really easy to change.
> Regards
> Anita
> > For example, "Reds" should go from (light) pink to red.
> > Currently, the first class in my legend always looks white, as many
> other parts of my map often do. Therefore it is hard to see where my data
> is and where not.
> > Another thing, changing it manually is hard because of the 7 stops in
> the ramps.
> > I'm happy to figure this out and make a PR, but would like to know
> other's opinions first.
> > Regards,
> > Raymond
> > Terglobo
> > Fahrenheitstraat 1
> > 5223 BJ 's-Hertogenbosch
> > The Netherlands
> > +31 (0) 6 25 31 49 83
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200615/2d76d8df/attachment.html>
