[Qgis-user] shapefiles
Raymond Nijssen r.nijssen at terglobo.nl
Mon Jun 15 23:08:53 PDT 2020
Ah, you'll need to change the layer order. Just drag and drop them at
the right spot in the layer panel, left from your map.
This is actually quite basic qgis knowledge, so you might consider
following some (online) tutorials to get started quickly.
Regards,
Raymond
On 16-06-2020 07:55, forestermcgannon wrote:
> when I "uncheck" the ortho layer, the property boundary (the shapefile)
> appears. When I display the ortho imagery again, no boundary. It is like
> the shapefile is "under" the ortho image, when I of course want it to
> show "on" the ortho image. most seems like a vector display issue to me.
> What do you think?
> Thanks
> Jim
> Jim McGannon
> Forestry Landscape Consultant, LLC
> Coloradotreearborist.com
> 303-526-1118
> -------- Original message --------
> From: Raymond Nijssen <r.nijssen at terglobo.nl>
> Date: 6/15/20 11:35 PM (GMT-07:00)
> To: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] shapefiles
> Hi Jim,
> That sounds a lot like a projection issue.
> Are your layers completely misaligned, like not overlapping at all? Or
> are they overlapping but with just a few (hundred) meters shift?
> An easy trick is adding the world layer and see which of your layers
> appears at the expected spot. You can do this by typing "world" in the
> coordinate bar beneath the map.
> Good luck!
> Raymond
> On 16-06-2020 05:24, forestermcgannon wrote:
>  > Why is my shapefile that I imported into project, not showing up with my
>  > orthoimage. The shapefile is a property line boundary.
>  > Thanks
>  > Jim
>  > _______________________________________________
>  > Qgis-user mailing list
>  > Qgis-user at lists.osgeo.org
>  > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>  > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
