[Qgis-user] Automatically ordering layers & best practice for transferring data
RMG
reikogoodwin at gmail.com
Tue Jun 16 10:46:33 PDT 2020
Hi Nicolas,
Many thanks. Load Them All looks promising.
Best regards,
Reiko Matsuda Goodwin
ComoƩ Monkey Project <https://www.facebook.com/ComoeMonkeyProject/>
Guenon Conservation Community
<http://facebook.com/GuenonConservationCommunity/>
On Tue, Jun 16, 2020 at 1:23 PM Nicolas Cadieux <
nicolas.cadieux at archeotec.ca> wrote:
> Hi,
> See below
> On 2020-06-16 12:39 p.m., RMG wrote:
> Hello,
> I have a lot of layers that are often similar in names and structures
> (e.g., 2018-01-20_daily-path_length, 2018-01-21_daily-path_length,
> 2018-01-22_daily-path_length ....), but not always. Is there a way to
> automatically order the layers by alphabetical order, date, etc.? I am not
> talking about grouping or sub-grouping. I am looking for a function that
> would allow us to sort them by certain specifics (e.g., order by
> modification date, order by rasters then vectors).
> There was an experimental sort layer plugin but I can't find it from QGIS
> 3x. Only on the web site. Maybe it has not been ported to qgis 3x.
> Anybody??? I believe the "Load them all" plugin could help also.
> https://plugins.qgis.org/plugins/SortLayers/
> Some code found here could help.
> https://gis.stackexchange.com/questions/318834/sort-layers-in-table-of-contents-in-qgis-3
> Second question. What is the best practice for transferring data from one
> external hard drive to another? A 2TB drive is full with a lot of Landsat
> images and now I would like to transfer the data to a 4TB one. How do I
> make sure that I have a smooth workflow without looking for layers within
> each project?
> Regards,
> Personally, I used Syncbacks free or SE.
> https://www.2brightsparks.com/welcome/syncback-syncbackse-syncbackpro.html?gclid=CjwKCAjw26H3BRB2EiwAy32zhVgBM3Bb_uJ-H69UvKghHCBr7yB8rDZ3evsXuY1ASKJYsv5O3HT0yxoC5_YQAvD_BwE
> You could always just copy and paste from one drive to the other. This
> can work if you are not accessing the files from the drives at the same
> time. Never *cut* and paste. That can be messy if things go wrong. If
> you keep the same file structure, QGIS projects should work on the second
> drive. Your hard drive may also have a free software to do the job. I
> would keep the first drive as a backup.
> Cheers!
> Nicolas
> Qgis-user mailing listQgis-user at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200616/4fafb592/attachment.html>
