[Qgis-user] Taken photo windows tablet
Saber Razmjooei
saber.razmjooei at lutraconsulting.co.uk
Wed Jun 17 06:47:27 PDT 2020
You can use https://inputapp.io which is based on QGIS. The Windows build
is experimental but should work. You can grab the latest version here:
https://www.dropbox.com/s/fs21z174ul2nllr/inputapp-win-x86_64-7da73a28ae42a65a8c8fce8a74e90710ca634ff6.exe?dl=0
You need to set your widget type to Attachment and it will use your camera.
For more information see:
https://www.lutraconsulting.co.uk/blog/2020/02/14/survey-qgis-input/
But in general, it is easier to use your Android or iOS device for
collecting data.
Kind regards
Saber
On Wed, 17 Jun 2020 at 12:03, Christine <geo.guide at web.de> wrote:
> Hi Guayente,
> there is a QGIS plugin 'ImportPhotos' that works fine.
> If you put all your photos that should be enclosed in a layer for QGIS, in
> one folder, the plugin will create a point layer with the recorded
> coordinates according the geo taggings of the photos. The resulting layer
> will be a styled GeoJSON Layer loaded in an open QGIS project. If you click
> with the plugin's 'Click Photos' tool on a photo point, the corresponding
> image is opened with the default image viewer of your system.
> This works with all geo tagged photos.
> Regards Christine
> Guayente Corral wrote
> > ... Is there a good way to capture images with the windows tablet camera
> > in the field and link them to data ?
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user mailing list
Saber Razmjooei
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200617/03c4dc26/attachment.html>
