[Qgis-user] Import GeoPDF (Raster/Vector) on macOS 3.12.3
Nyall Dawson nyall.dawson at gmail.com
Wed Jun 17 15:43:50 PDT 2020
On Thu, 18 Jun 2020 at 05:50, Andreas Neumann <a.neumann at carto.net> wrote:
> Hi Mike,
> What is the gdal version that QGIS is built against (see Help --> about
> menu)? You need at least version 3 or higher. Otherwise it won't work.
Actually the question was about GeoPDF import -- which should work
with GDAL 2.x, so long as the GDAL library was built with support for
a PDF backend.
I think you should report this on this ticket:
https://github.com/qgis/QGIS-Mac-Packager/issues/48
Nyall
> Greetings,
> Andreas
> Am 17.06.20 um 19:43 schrieb Mike Flannigan:
> > We talked about GeoPDFs on 4/21/2020.
> > It appears some GeoPDFs can be opened on
> > Windows.  So far I have not found a GeoPDF
> > that can be opened by QGIS on my Linux Mint.
> > It gives:
> > Invalid Data Source
> > or
> > Invalid Layer
> > Mike
> > On 6/17/20 9:49 AM, qgis-user-request at lists.osgeo.org wrote:
> >> Hello,
> >> I am just wondering if the ability to import a GeoPDF is or will be
> >> available for macOS.
> >> I noticed some people are able to import a GeoPDF into QGIS as Raster or
> >> Vector, but I have never had the pleasure on mac.  I presume due to the
> >> lack of GDAL PDF libraries built for mac.
> >> Thank you,
> >> Mars
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
