[Qgis-user] Import GeoPDF (Raster/Vector) on macOS 3.12.3
Mike Flannigan mikeflan at att.net
Sat Jun 20 14:28:55 PDT 2020
Even though the issue is probably immaterial,
the gdal version at /usr/share/gdal on
my system is 2.2.
Mike
On 6/17/20 6:00 PM, qgis-user-request at lists.osgeo.org wrote:
> On Thu, 18 Jun 2020 at 05:50, Andreas Neumann<a.neumann at carto.net>  wrote:
>> Hi Mike,
>> What is the gdal version that QGIS is built against (see Help --> about
>> menu)? You need at least version 3 or higher. Otherwise it won't work.
> Actually the question was about GeoPDF import -- which should work
> with GDAL 2.x, so long as the GDAL library was built with support for
> a PDF backend.
> I think you should report this on this ticket:
> https://github.com/qgis/QGIS-Mac-Packager/issues/48
> Nyall
>> Greetings,
>> Andreas
>> Am 17.06.20 um 19:43 schrieb Mike Flannigan:
>>> We talked about GeoPDFs on 4/21/2020.
>>> It appears some GeoPDFs can be opened on
>>> Windows.  So far I have not found a GeoPDF
>>> that can be opened by QGIS on my Linux Mint.
>>> It gives:
>>> Invalid Data Source
>>> or
>>> Invalid Layer
>>> Mike
>>> On 6/17/20 9:49 AM,qgis-user-request at lists.osgeo.org  wrote:
>>>> Hello,
>>>> I am just wondering if the ability to import a GeoPDF is or will be
>>>> available for macOS.
>>>> I noticed some people are able to import a GeoPDF into QGIS as Raster or
>>>> Vector, but I have never had the pleasure on mac.  I presume due to the
>>>> lack of GDAL PDF libraries built for mac.
>>>> Thank you,
>>>> Mars
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200620/9d06f935/attachment.html>
