[Qgis-user] Hillshade Rough Blocks for 1m Rasters?
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Mon Jun 29 15:32:22 PDT 2020
If your x and y distance unit is different from the z distance (like
long lat degrees for x and y and meters for z), you will need a z
Factor, or you need to save the raster in a crs that has x,y,z in the
same unit (like meter).
https://www.esri.com/arcgis-blog/products/product/imagery/setting-the-z-factor-parameter-correctly/
You can also improve the look in the layer/Symbology/Resampling and
select cubic for "zoomed in" and Average for "zoomed out".
Nicolas
On 2020-06-29 6:23 p.m., Alister Hood wrote:
> It does shade the pixel, but it also shades the edges unless the layer
> is being reprojected.
> There is a ticket for this, but you can workaround it by enabling
> resampling for that layer.
> Date: Mon, 29 Jun 2020 16:57:11 -0400
> From: <cgray at graytechsoftware.com <mailto:cgray at graytechsoftware.com>>
> To: <qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>>
> Subject: [Qgis-user] Hillshade Rough Blocks for 1m Rasters?
> Message-ID: <024601d64e57$dcbddd00$96399700$@graytechsoftware.com
> <http://graytechsoftware.com>>
> Content-Type: text/plain; charset="utf-8"
> If I use a 1m resolution raster on a CRS in meters and render it as a
> hillshade, it appears to shade the edges of each pixel instead of
> the pixel
> itself:
> If I use, a raster made in a CRS with ft for units displayed on a
> CRS in
> meters, it renders each pixel smoothly:
> How do I get the hillshade to render smoothly always, especially
> in a CRS in
> meters when using metric units for the raster?
> Thank you, Chris
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200629/8f3ae99f/attachment.html>
