[Qgis-user] Hillshade Rough Blocks for 1m Rasters?
Priv.-Doz. Dr. Maria Shinoto maria.shinoto at zaw.uni-heidelberg.de
Mon Jun 29 16:15:11 PDT 2020
A month ago or so I had exactly the same problem and could solve it with these tips from Nicolas. Good luck!
Maria
> Am 30.06.2020 um 07:32 schrieb Nicolas Cadieux <njacadieux.gitlab at gmail.com>:
> Hi,
> If your x and y distance unit is different from the z distance (like long lat degrees for x and y and meters for z), you will need a z Factor, or you need to save the raster in a crs that has x,y,z in the same unit (like meter).
> https://www.esri.com/arcgis-blog/products/product/imagery/setting-the-z-factor-parameter-correctly/
> You can also improve the look in the layer/Symbology/Resampling and select cubic for "zoomed in" and Average for "zoomed out".
> Nicolas
> On 2020-06-29 6:23 p.m., Alister Hood wrote:
>> It does shade the pixel, but it also shades the edges unless the layer is being reprojected.
>> There is a ticket for this, but you can workaround it by enabling resampling for that layer.
>> Date: Mon, 29 Jun 2020 16:57:11 -0400
>> From: <cgray at graytechsoftware.com>
>> To: <qgis-user at lists.osgeo.org>
>> Subject: [Qgis-user] Hillshade Rough Blocks for 1m Rasters?
>> Message-ID: <024601d64e57$dcbddd00$96399700$@graytechsoftware.com>
>> Content-Type: text/plain; charset="utf-8"
>> If I use a 1m resolution raster on a CRS in meters and render it as a
>> hillshade, it appears to shade the edges of each pixel instead of the pixel
>> itself:
>> If I use, a raster made in a CRS with ft for units displayed on a CRS in
>> meters, it renders each pixel smoothly:
>> How do I get the hillshade to render smoothly always, especially in a CRS in
>> meters when using metric units for the raster?
>> Thank you, Chris
>> Qgis-user mailing list
>> List info:
>> https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:
