[Qgis-user] Hillshade Rough Blocks for 1m Rasters?
Nicolas Cadieux njacadieux.gitlab at gmail.com
Tue Jun 30 11:17:09 PDT 2020
To my knowledge, what you are seeing is just the result of zooming in too much using the nearest neighbour algorithm.  I don’t think it’s a bug. If you change the sun angle and the sun position, you may have better results. Then, play with the Contrast and layer blending.  I have seen this Pixel border effect on QGIS since version 1.8.  Someone correct me if I am wrong.
Nicolas Cadieux
Ça va bien aller!
> Le 29 juin 2020 à 23:37, cgray at graytechsoftware.com a écrit :
> Nicolas,
> My x, y, and z are all in meters for my raster. The CRS for the project is also x, y, and z in meters.
> I tried your suggestion for changing the resampling. It definitely eliminated the problem, however it results in too much smoothing for my purpose. I do want to be able to see the actual pixel, but I want that pixel to be a single color representative of its value rather than a color with a boarder as shown in my screenshots.
> It seems this only occurs when the raster resolution matches the base unit of the CRS. I think this is a bug, but I have not exhausted the configuration options yet.
> Thank you, Chris
> -----Original Message-----
> From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Priv.-Doz. Dr. Maria Shinoto
> Sent: Monday, June 29, 2020 7:15 PM
> To: Nicolas Cadieux <njacadieux.gitlab at gmail.com>
> Cc: Alister Hood <alister.hood at gmail.com>; qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] Hillshade Rough Blocks for 1m Rasters?
> A month ago or so I had exactly the same problem and could solve it with these tips from Nicolas. Good luck!
> Maria
>> Am 30.06.2020 um 07:32 schrieb Nicolas Cadieux <njacadieux.gitlab at gmail.com>:
>> Hi,
>> If your x and y distance unit is different from the z distance (like long lat degrees for x and y and meters for z), you will need a z Factor, or you need to save the raster in a crs that has x,y,z in the same unit (like meter).
>> https://www.esri.com/arcgis-blog/products/product/imagery/setting-the-
>> z-factor-parameter-correctly/
>> You can also improve the look in the layer/Symbology/Resampling and select cubic for "zoomed in" and Average for "zoomed out".
>> Nicolas
>>> On 2020-06-29 6:23 p.m., Alister Hood wrote:
>>> It does shade the pixel, but it also shades the edges unless the layer is being reprojected.
>>> There is a ticket for this, but you can workaround it by enabling resampling for that layer.
>>> Date: Mon, 29 Jun 2020 16:57:11 -0400
>>> From: <cgray at graytechsoftware.com>
>>> To: <qgis-user at lists.osgeo.org>
>>> Subject: [Qgis-user] Hillshade Rough Blocks for 1m Rasters?
>>> Message-ID: <024601d64e57$dcbddd00$96399700$@graytechsoftware.com>
>>> Content-Type: text/plain; charset="utf-8"
>>> If I use a 1m resolution raster on a CRS in meters and render it as a
>>> hillshade, it appears to shade the edges of each pixel instead of the
>>> pixel
>>> itself:
>>> If I use, a raster made in a CRS with ft for units displayed on a CRS
>>> in meters, it renders each pixel smoothly:
>>> How do I get the hillshade to render smoothly always, especially in a
>>> CRS in meters when using metric units for the raster?
>>> Thank you, Chris
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info:
>>> https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe:
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
