[Qgis-user] QGIS uninstalled after GDAL PPA install
J. M jimimckay at gmail.com
Sun Mar 1 04:16:08 PST 2020
Success!! I erased the four offending repositories and the
installation went ahead fine. It installed the latest version (3.12?) which
I didn't expect, and it appears to work on my OS. I ran apt-cache policy
libgdal20 and it returned 2.2.3, so that's perfect. I'll have to enable it
somehow in Blender, but that's another problem.
My profound thanks to the team for helping me; you're incredible!
Cheers,
Jimi.
On Fri, Feb 28, 2020 at 9:38 PM Andre Joost <andre+joost at nurfuerspam.de>
wrote:
> Am 28.02.20 um 20:48 schrieb J. M:
> > Hi Andre,
> > Okay thanks once again... I'll have a go, though I'm not sure how to
> remove
> > them. Would it be 'sudo apt-get remove gdal-bin' or does it need 'sudo
> > apt-get remove gdal-bin 3.0.2+dfsg-1~bionic2'?
> The first one should be ok.
> > I ask because I don't know
> > if gdal-bin is something generic used elsewhere and I have to denominate
> > that. As I don't really understand what those files are, I'm wary of
> > removing them without being sure of the syntax first. Can I be sure they
> > aren't needed for another program, for example Blender?
> You can install gdal-bin later from the main Ubuntu repo, which will be
> version 2.2.3. Blender should be happy with it. I doubt they support
> GDAL 3 yet.
> > So once those four files are removed I can try sudo apt-get install
> > libgdal20=2.2.3+dfsg-2 again? And once I have libgdal20 installed then I
> > can run sudo apt-get install qgis qgis-plugin-grass python3-qgis? If I'm
> > missing anything else then please let me know..
> Run the apt-cache policy libgdal20 again. If it offers you version 2.2.3
> only, then QGIS sould install properly.
> HTH,
> Andre Joost
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200301/3dbf1c54/attachment.html>
