[Qgis-user] QGIS uninstalled after GDAL PPA install
Lorenzo-Outlook morettilorenzo at outlook.com
Wed Mar 4 15:06:13 PST 2020
Hi all
I also was able to install the new version 3.12 in Ubuntu 18.04 following the instructions by eliminating the ubuntugis repo. But QGIS is not complete: the problem is strange because QGIS opens and inside it is missing many CRS projections (for example the geographical WGS84, EPSG:4326 or 3857 and others). It seems that the PROJ4 library version 4.9.3 with which QGIS is compiled does not contain some CRS. Everything else works but without these projections QGIS is not much need. Of course the server version also has this problem and is therefore unusable. I went back to the ubuntugis repo and reinstalled QGIS 3.10.2 which works fine.
Did someone have the same problem or did it just happen to me?
Bye
Lorenzo
> Il giorno 1 mar 2020, alle ore 13:16, J. M <jimimckay at gmail.com> ha scritto:
> Success!! I erased the four offending repositories and the installation went ahead fine. It installed the latest version (3.12?) which I didn't expect, and it appears to work on my OS. I ran apt-cache policy libgdal20 and it returned 2.2.3, so that's perfect. I'll have to enable it somehow in Blender, but that's another problem.
> My profound thanks to the team for helping me; you're incredible!
> Cheers,
> Jimi.
> On Fri, Feb 28, 2020 at 9:38 PM Andre Joost <andre+joost at nurfuerspam.de <mailto:andre%2Bjoost at nurfuerspam.de>> wrote:
> Am 28.02.20 um 20:48 schrieb J. M:
> > Hi Andre,
> > Okay thanks once again... I'll have a go, though I'm not sure how to remove
> > them. Would it be 'sudo apt-get remove gdal-bin' or does it need 'sudo
> > apt-get remove gdal-bin 3.0.2+dfsg-1~bionic2'?
> The first one should be ok.
> > I ask because I don't know
> > if gdal-bin is something generic used elsewhere and I have to denominate
> > that. As I don't really understand what those files are, I'm wary of
> > removing them without being sure of the syntax first. Can I be sure they
> > aren't needed for another program, for example Blender?
> You can install gdal-bin later from the main Ubuntu repo, which will be
> version 2.2.3. Blender should be happy with it. I doubt they support
> GDAL 3 yet.
> > So once those four files are removed I can try sudo apt-get install
> > libgdal20=2.2.3+dfsg-2 again? And once I have libgdal20 installed then I
> > can run sudo apt-get install qgis qgis-plugin-grass python3-qgis? If I'm
> > missing anything else then please let me know..
> Run the apt-cache policy libgdal20 again. If it offers you version 2.2.3
> only, then QGIS sould install properly.
> HTH,
> Andre Joost
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>_______________________________________________
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200305/f1f11cf6/attachment.html>
