[Qgis-user] Using relations and transaction groups
Matthias Kuhn matthias at opengis.ch
Mon Mar 2 22:18:52 PST 2020
Hi Rhys,
Ironically, this situation is exactly what transaction mode has been
added for (to avoid the situation where someone clicks the save windows
button before the save footprint button).
The solution is not that obvious though (and might be poorly
documented): Enable "deferred constraint checks" in your database and it
will only check if foreign key constraints are ok at commit time (when
you save it) and not while editing. If by any chance you get around to
adding this information into the documentation, this will be much
appreciated!
Bests
Matthias
On 3/3/20 6:23 AM, Rhys A.D. Stewart wrote:
> Greetings All,
> I'm working with transaction groups and tables with relations
> (database foreign keys). Let's say that there are two tables,
> 'building_footprints'  and 'windows'. The windows table references the
> 'building_footprints' table. I've added the relations in QGIS through
> the Project properties | relations dialog so that when editing
> 'building_footprints' I can add a child record for 'windows'. Now
> because I have transaction groups active, the changes are pushed back
> to the database immediately, if I create a child record before saving
> the parent record this causes a problem because the parent record
> doesn't exist. It is often the case that I am going to add child
> records when I'm creating the parent record, so adding a parent
> record, saving it, then editing it just to add the child record
> becomes cumbersome.
> I figured that someone must've had this issue before, but can't seem
> to find any documentation about this. Is there a workaround for this?
> (other than not using transaction groups and saving each layer
> individually)  Or have I just missed something extremely obvious?
> Rhys
> Peace & Love | Live Long & Prosper
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200303/1d6932c1/attachment-0001.html>
