[Qgis-user] Atlas Generation
Håvard Tveite havard.tveite at nmbu.no
Wed Mar 18 16:20:38 PDT 2020
The following procedure works for me (QGIS 3.12).
0) I assume that the map for the "report" is already prepared.
1) Create a new report (*Project-> New Report*).
2) In the *Report Organizer*, add a *Field Group Section*
    under *Report* by pressing the green plus-button (+) and
    selecting *Field Group Section*.
3) Make sure that "Group" is selected in the *Report Organizer*,
    and select your point layer in *Layer*.
4) Select a field (from that layer) for sorting (*Field*).
5) Check *Include body* and click the *Edit* button to the right.
    If you right-click in the white "sheet" that shows up on the
    gray canvas, you can set the page size and orientation.
    Specify "Custom" with a *Width* of 200 mm and a *Height* of
    200 mm in *Item Properties* to the right.
6) Add your map (Add Item-> Add Map, by dragging out the rectangle
    for it on the canvas).
7) In the *Item Properties* of the map, select your preferred
    map *Scale*.
8) Scroll down and check *Controlled by Report*. *Fixed scale*
    will be the selected (and, for point layers, only possible)
    option.
9) Export your map to PDF and check the results
    (I get 20cm x 20 cm pages)
hopefully this also works with QGIS 3.4 and 3.10.
Håvard
On 18.03.2020 23:03, stellar0645 wrote:
> Hello,
> I simply want to create a multi-page map book of a large area of southern
> Arizona.  Not an atlas of different features but a simple book of pages
> which divides the main map into smaller equal-sized pages at the same scale.
> Using QGIS 3.4.4.
> I've researched this to no end and searched this forum but am stuck at
> defining the page size of all things.  I have a regular grid of points that
> define the centre of each page but I cannot define the page size.  Page
> setup does not seem to have any effect.
> The Atlas configuration seems to be scattered among several areas and I'm at
> a loss as to how they all interact and function.
> Is there a STEP by STEP recipe for creating a map book once the grid has
> been defined?
> Thanks very much . . . .
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user mailing list
