[Qgis-user] API Key required
Nyall Dawson nyall.dawson at gmail.com
Thu Mar 19 16:05:41 PDT 2020
On Fri, 20 Mar 2020 at 04:29, Aminou BIO <aminoubio at gmail.com> wrote:
> Hello,
> I'm using the 2.18.4 version of Qgis
That's issue number 1. You should be using at least QGIS 3.10.3. 2.18
is **ancient**.
>. I use to get this message "OpenLayers Plugin: Printing and rotating of Javascript API based layers is currently not supported"
This is issue number 2. Don't use the OpenLayers plugin, the
"QuickMapServices" plugin is better supported in modern QGIS versions
and generally an easier plugin to use.
Nyall
 when i ask to display Google Maps or "API key Required" when i try to
display OSM/Thunderforest maps.
> Can somebody help?
> Best Regards
> Qgis-user mailing list
