[Qgis-user] API Key required
Aminou BIO aminoubio at gmail.com
Thu Mar 19 16:30:58 PDT 2020
Thanks, I'll check it out.
Best regards
Le ven. 20 mars 2020 à 00:05, Nyall Dawson <nyall.dawson at gmail.com> a
écrit :
> On Fri, 20 Mar 2020 at 04:29, Aminou BIO <aminoubio at gmail.com> wrote:
> > Hello,
> > I'm using the 2.18.4 version of Qgis
> That's issue number 1. You should be using at least QGIS 3.10.3. 2.18
> is **ancient**.
> >. I use to get this message "OpenLayers Plugin: Printing and rotating of
> Javascript API based layers is currently not supported"
> This is issue number 2. Don't use the OpenLayers plugin, the
> "QuickMapServices" plugin is better supported in modern QGIS versions
> and generally an easier plugin to use.
> Nyall
>  when i ask to display Google Maps or "API key Required" when i try to
> display OSM/Thunderforest maps.
> > Can somebody help?
> > Best Regards
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200320/4201b3e8/attachment.html>
