[Qgis-user] importing data to map
Didier Peeters dpeeter1 at ulb.ac.be
Fri Mar 20 06:38:38 PDT 2020
You need to use a Relation, in the project properties (Menu: Project > Properties > Relations).
See these videos to understand how it works :
https://youtu.be/MeBnasFHGGQ
https://youtu.be/OowgI1b2ihw
Cheers,
Didier
> Le 20 mars 2020 à 12:33, Boaz Bar Ilan <boazprosie at gmail.com> a écrit :
> hi there
>  I got data xcls which describes functions in relation to parcells
> im trying to import this spreadsheet to a map of parcells  and what happen of course that if there are 2 functions in the same parcel - it shows only one!
> how can I show  2 functions or more related to the same parcel  ?
> I can use the add polygon feature but than it should be done manually one by one
> is there different way ?
> thanks
> boaz
> Qgis-user mailing list
