[Qgis-user] importing data to map
Didier Peeters dpeeter1 at ulb.ac.be
Sat Mar 21 02:25:53 PDT 2020
I don't know about your data or what you call a "function" here, but yes you need to have it loaded in QGis as a layer (with or without geometry).  To do so and supposing you have a .xls or .xlsx file you can install the 'Spreadsheet Layers' plugin, which  adds a "Add spreadsheet layer" entry in "Layer" / "Add new Layer" menu and a corresponding button in the "Layers" toolbar.  <https://github.com/camptocamp/QGIS-SpreadSheetLayers>  Alternatively you could maybe convert your data into a .csv file and load it as well.   Once your file is loaded you should be able to create the relation.
Didier
> Le 21 mars 2020 à 08:49, Boaz Bar Ilan <boazprosie at gmail.com> a écrit :
> hi
> thanks
>  I need  to present all the functions as one layer so how can this help me?
> ‫בתאריך יום ו׳, 20 במרץ 2020 ב-15:39 מאת ‪Didier Peeters‬‏ <‪dpeeter1 at ulb.ac.be <mailto:dpeeter1 at ulb.ac.be>‬‏>:‬
> Hi,
> You need to use a Relation, in the project properties (Menu: Project > Properties > Relations).
> See these videos to understand how it works :
> https://youtu.be/MeBnasFHGGQ <https://youtu.be/MeBnasFHGGQ>
> https://youtu.be/OowgI1b2ihw <https://youtu.be/OowgI1b2ihw>
> Cheers,
> Didier
> > Le 20 mars 2020 à 12:33, Boaz Bar Ilan <boazprosie at gmail.com <mailto:boazprosie at gmail.com>> a écrit :
> > hi there
> >  I got data xcls which describes functions in relation to parcells
> > im trying to import this spreadsheet to a map of parcells  and what happen of course that if there are 2 functions in the same parcel - it shows only one!
> > how can I show  2 functions or more related to the same parcel  ?
> > I can use the add polygon feature but than it should be done manually one by one
> > is there different way ?
> > thanks
> > boaz
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200321/82aa2327/attachment.html>
