[Qgis-user] Isochrones
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Wed Mar 25 08:35:17 PDT 2020
The first thing I would do is to check the network integrity.  Perhaps some road are not connected (snapped).  You also need a snap and break at every intersection. You can do some of this by exporting all the end node. Check for multiline vs lines. You can split all of those in the vector menu.  Your problems are likely linked to a bad network topology. Users of that network could perhaps confirm this? I have used it but not for this type of stuff.
Nicolas Cadieux
> Le 25 mars 2020 à 10:22, Tyler Veinot <tylerkveinot at gmail.com> a écrit :
> All;
> I have a network, Canada National Road Network it is a free download, that I am trying to use for PEI and the City of Charlottetown to find out what area is within X time of various points of interest. I used Here for QGIS to get the initial result but QGIS has a tool built in Network Analyst that has Service Area from Network and from Point, also and QNEAT that has 6 isochrone tools for doing exactly what I am trying to do. For some reason though the results don't seem to match the network. I would expect the from the point of origin the shortest times to be along the lines and radiate out.
> What tools are you guys using to do this kind of work? Do my values for forward backward both direction need to be numeric? Any tutorials on using these tools?
> Thanks;
> Tyler
> Qgis-user mailing list
