[Qgis-user] Extracting contours from ESRI topo?
Randal Hale rjhale at northrivergeographic.com
Sat Mar 28 06:29:52 PDT 2020
One good source might be https://www2.jpl.nasa.gov/srtm/ - the Space
Shuttle Radar Topography Data.
If you're working in Canada you could check to see if the province has
an open data portal with elevation data.
Good luck!
Randy
On 3/28/20 4:42 AM, Andreas Neumann wrote:
> Hi Brock,
> Perhaps the semi-automated "Raster Tracer" plugin could help?
> See http://plugins.qgis.org/plugins/raster_tracer/ ,
> https://github.com/mkondratyev85/raster_tracer/ and a video
> demonstrating how to use it https://www.youtube.com/watch?v=D3Mh4wpSEMM
> I think you need a proper raster data source for it (RGB for now) and
> it probably wouldn't work on tiled raster, such as served by Base
> Maps. But there might be solutions to convert a tiled base map to a
> GeoTIFF file ...
> Or you get to the source, like the USGS topo file, which should be
> available as Geotiff files.
> Hope this helps a bit.
> Greetings,
> Andreas
> Am 28.03.20 um 01:09 schrieb Brock Riedell:
>> Does anybody know if it is possible to extract the contour lines (say
>> as a shapefile) from a windowed portion of ESRI Topo (as available on
>> QuickMapServices)? I'm working on an minerals exploration project
>> with very limited topo coverage, and would far prefer to use the ESRI
>> contours.
>> Brock
>> Qgis-user mailing list
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
Randal Hale
(p) 423.653.3611
http://www.northrivergeographic.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200328/30db7162/attachment.html>
