[Qgis-user] Extracting contours from ESRI topo?
Andreas Neumann a.neumann at carto.net
Sat Mar 28 01:42:34 PDT 2020
Hi Brock,
Perhaps the semi-automated "Raster Tracer" plugin could help?
See http://plugins.qgis.org/plugins/raster_tracer/ ,
https://github.com/mkondratyev85/raster_tracer/ and a video
demonstrating how to use it https://www.youtube.com/watch?v=D3Mh4wpSEMM
I think you need a proper raster data source for it (RGB for now) and it
probably wouldn't work on tiled raster, such as served by Base Maps. But
there might be solutions to convert a tiled base map to a GeoTIFF file ...
Or you get to the source, like the USGS topo file, which should be
available as Geotiff files.
Hope this helps a bit.
Greetings,
Andreas
Am 28.03.20 um 01:09 schrieb Brock Riedell:
> Does anybody know if it is possible to extract the contour lines (say
> as a shapefile) from a windowed portion of ESRI Topo (as available on
> QuickMapServices)?  I'm working on an minerals exploration project
> with very limited topo coverage, and would far prefer to use the ESRI
> contours.
> Brock
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200328/0a5d9be2/attachment.html>
