[Qgis-user] How do I get QGIS 3.10 export to export GeoPDF
Alexandre Neto senhor.neto at gmail.com
Mon Oct 5 11:03:51 PDT 2020
Conda-forge installation comes with GDAL 3.0, if I recall. So, probably
will be able to export geopdf, but beware it has some limitations because
of not suportting QtWebkit, so it's not a solution for every day work.
Best regards,
Alexandre Neto
A segunda, 5/10/2020, 18:26, Peter Petrik <
peter.petrik at lutraconsulting.co.uk> escreveu:
> Hi, unfortunately, with the all-in-one installer (official) you can't,
> since it runs on gdal2. But you can with the latest nightly
> https://qgis.org/downloads/macos/nightly that will become the next QGIS
> 3.16 release.
> For other distributions (Kyngchaos, conda, homebrew, macports, ?) I have
> no clue what they support.
> Cheers,
> Peter
> On Mon, Oct 5, 2020 at 4:54 PM Dan Hinckley <dbh at suiattle.org> wrote:
>> Running QGIS 3.10 on a Mac mini with High Sierra. When I use
>> Project/Import/Export/Export Map to PDF..., the GeoPDF option is
>> unavailable, saying it requires GDAL 3.
>> I have GDAL 3 installed via Kyngchaos' version, and also tried using the
>> MacPorts version for my default Python, 2.7.6.
>> Reboot, restart QGIS, with no change. is there a PATH issue, or a config
>> option I have not found?
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201005/b2a6f6cc/attachment-0001.html>
