[Qgis-user] QGIS and SAGA 7.3.0
Bernd Vogelgesang bernd.vogelgesang at gmx.de
Sat Oct 17 04:00:30 PDT 2020
Hi Nick,
found this quiet old conversation:
There is a QGIS plugin for QGIS higher than 3.4 that works with SAGA 7.2.
It is called SAGA nextgen.
It works as is under Windows with SAGA 7.3, and I'm pretty sure it would
work in Ubuntu if you change the provider.py file so that REQUIRED_VERSION =
'7.2.' becomes REQUIRED_VERSION = '7.3.'
https://www.mail-archive.com/ubuntu@lists.osgeo.org/msg01605.html
Being on Linux Mint, this trick worked as I remember. Not sure about Ubuntu 20.04 but you may give it a try.
Why this hasn't been updated yet is beyond my understanding.
Cheers,
Bernd
On 17.10.20 11:56, Nick Hopton wrote:
> Ubuntu 20.04, QGIS 3.14.16, SAGA 7.3.0
> In QGIS I lean quite heavily on SAGA algorithms, which worked fine until I
> upgraded to Ubuntu 20.04 (focal). This forced an upgrade of SAGA to Version
> 7.3.0. Trying to use this from the Processing Toolbox resulted in a warning
> and problems, so I installed the SAGA NextGen Provider, in the hope that
> this would fix them.  It hasn't, but I'm far from sure that I've set the
> required 'SAGA folder' correctly. It would be helpful if someone could tell
> me what this should be, or how to find out what it should be.
> I think SAGA 7.3.0 is correctly installed, is starts correctly with
> 'saga_gui' from a command line.
> Best wishes,
> Nick.
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201017/75a72695/attachment.html>
