[Qgis-user] error message when clipping raster
Charles Dixon-Paver
charles at kartoza.com
Fri Oct 30 02:51:49 PDT 2020
You should be able to get more information on the error by using the log
messages as indicated by the error message. To open the log messages use
View >> Panels >> Log Messages.
The output there should help in determining the cause of the issue. Also,
you mention you don't have this issue, but are you using the same operating
system etc?
The raster extraction tool is a GDAL operation (afaik), so you should be
able to use the command generated from the command line as well.
On Fri, 30 Oct 2020 at 11:24, Azzurra Lentini <azzurralentini at gmail.com>
wrote:
> Dear all, I am giving a class of Qgis (MSc in earth science) and one of my
> students had this problem when she tried to clip a raster file.
> I don't have this problem with the same file and using the same command
> and Qgis version.
> She must clip a raster .tif file.
> We are using Qgis 3.10.3 version and from the menu bar we are using
> RASTER>EXTRACTION>CLIP RASTER BY EXTENT
> The message that Qgis gave is:
> The following layers were not correctly
> generated.<ul><li>C:/Users/pc/Documents/Es1VetereG/Elaboration/Bacino_Idrog/Layout_BacIdroChio_Raster_Clip.tif</li></ul>You
> can check the 'Log Messages Panel' in QGIS main window to find more
> information about the execution of the algorithm.
> Thank you for any suggestion!
> Azzurra
> Lecturer GIS University "Roma Tre"
> Consultant Environmental Risk Prevention and Hydrogeology
> AZZURRA LENTINI
> Italy Mobile Tel.: **(39) 338 24 40 676
> SKYPE azzurrahydro
> *azzurralentini at gmail.com <azzurralentini at gmail.com>*
> *azzurra.lentini at uniroma3.it <azzurra.lentini at uniroma3.it> *
> *Par respect pour l'environnement,*
> *n'imprimez ce mail qu'en cas d'absolue nécessité*
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201030/446ea6ca/attachment.html>
