[Qgis-user] Mac computer configuration
RMG reikogoodwin at gmail.com
Wed Sep 9 07:04:44 PDT 2020
Hello Donal and list,
Many thanks for asking. Below is the info:
Model Name: MacBook Pro
      Model Identifier: MacBookPro12,1
      Processor Name: Intel Core i5
      Processor Speed: 2.9 GHz
      Number of Processors: 1
      Total Number of Cores: 2
      L2 Cache (per Core): 256 KB
      L3 Cache: 3 MB
      Hyper-Threading Technology: Enabled
      Memory: 8 GB
      Boot ROM Version: 192.0.0.0.0
      SMC Version (system): 2.28f7
Apple SSD Controller:
      Vendor: Apple
      Product: SSD Controller
      Physical Interconnect: PCI
      Link Width: x4
      Link Speed: 5.0 GT/s
      Description: AHCI Version 1.30 Supported
APPLE SSD SM0512G:
      Capacity: 500.28 GB (500,277,790,720 bytes)
      Model: APPLE SSD SM0512G
      Revision: BXW1SA0Q
      Native Command Queuing: Yes
      Queue Depth: 32
      Removable Media: No
      Detachable Drive: No
      BSD Name: disk0
      Medium Type: Solid State
      TRIM Support: Yes
      Partition Map Type: GPT (GUID Partition Table)
      S.M.A.R.T. status: Verified
Best wishes,
Reiko Matsuda Goodwin
ComoƩ Monkey Project <https://www.facebook.com/ComoeMonkeyProject/>
Guenon Conservation Community
<http://facebook.com/GuenonConservationCommunity/>
On Wed, Sep 9, 2020 at 5:05 AM Donal Hunt <donal.hunt at gmail.com> wrote:
> Can you provide the following information from the command line (run these
> commands and paste the output):
> *$* system_profiler SPHardwareDataType
> *$* system_profiler -detailLevel mini SPSerialATADataType SPParallelATADataType
> ** you may want to remove/redact the "Serial Number (system)" and
> "Hardware UUID" values before emailing.*
> That will provide some information on your existing system and disks which
> will make it easier to determine what appropriate replacements are needed.
> Normally, I would look at CPU performance, amount of RAM and disk speeds
> (HDD vs SSD vs NVMe makes a huge difference).
> Hope that helps!
> Donal
> On Wed, 9 Sep 2020 at 02:00, RMG <reikogoodwin at gmail.com> wrote:
>>  Hello QGIS users on Macs,
>> I would like advice on purchasing a new Mac. My Mac is 5 years old and
>> cannot handle heavy-duty QGIS procedures. I process many satellite images
>> and some vector files with 30 m grids have millions of features, for
>> example. To process anything is taking too long. I know there has been a
>> discussion on ARMS hardware, but that seems a few years away. So right now,
>> what would you recommend? I plan to partition the hard drive to handle
>> ArcGIS as well. I do not think I can afford a dream machine like Mac Pro,
>> though. Is a Mac mini something that you guys use and recommend?
>> Best wishes,
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200909/9f727eb0/attachment.html>
