[Qgis-user] Mac computer configuration
Donal Hunt
donal.hunt at gmail.com
Wed Sep 9 14:26:10 PDT 2020
You can compare the CPU ratings of your current machine vs the ratings for
the currently available i5 and i7 models of the mac mini here:
https://www.cpubenchmark.net/compare/Intel-i5-5287U-vs-Intel-i5-8500B-vs-Intel-i7-8700B/2575vs3382vs3388
Additional memory (16gb or 32gb) may also help. You could potentially
attach a fast nvme drive to the thunderbolt 3 port (you can't upgrade the
SSD on the latest generation of mac minis as they are soldered to the logic
board).
I would highly recommend profiling where the bottleneck / performance
issues are occurring. Tools such as activity monitor, instruments and
sample can provide more insight. See
https://gist.github.com/loderunner/36724cc9ee8db66db305 for some
suggestions.
Hope that helps.
Donal
On Wed, 9 Sep 2020 at 15:04, RMG <reikogoodwin at gmail.com> wrote:
> Hello Donal and list,
> Many thanks for asking. Below is the info:
> Model Name: MacBook Pro
> Model Identifier: MacBookPro12,1
> Processor Name: Intel Core i5
> Processor Speed: 2.9 GHz
> Number of Processors: 1
> Total Number of Cores: 2
> L2 Cache (per Core): 256 KB
> L3 Cache: 3 MB
> Hyper-Threading Technology: Enabled
> Memory: 8 GB
> Boot ROM Version: 192.0.0.0.0
> SMC Version (system): 2.28f7
> Apple SSD Controller:
> Vendor: Apple
> Product: SSD Controller
> Physical Interconnect: PCI
> Link Width: x4
> Link Speed: 5.0 GT/s
> Description: AHCI Version 1.30 Supported
> APPLE SSD SM0512G:
> Capacity: 500.28 GB (500,277,790,720 bytes)
> Model: APPLE SSD SM0512G
> Revision: BXW1SA0Q
> Native Command Queuing: Yes
> Queue Depth: 32
> Removable Media: No
> Detachable Drive: No
> BSD Name: disk0
> Medium Type: Solid State
> TRIM Support: Yes
> Partition Map Type: GPT (GUID Partition Table)
> S.M.A.R.T. status: Verified
> Best wishes,
> Reiko Matsuda Goodwin
> ComoƩ Monkey Project <https://www.facebook.com/ComoeMonkeyProject/>
> Guenon Conservation Community
> <http://facebook.com/GuenonConservationCommunity/>
> On Wed, Sep 9, 2020 at 5:05 AM Donal Hunt <donal.hunt at gmail.com> wrote:
>> Can you provide the following information from the command line (run
>> these commands and paste the output):
>> *$* system_profiler SPHardwareDataType
>> *$* system_profiler -detailLevel mini SPSerialATADataType SPParallelATADataType
>> ** you may want to remove/redact the "Serial Number (system)" and
>> "Hardware UUID" values before emailing.*
>> That will provide some information on your existing system and disks
>> which will make it easier to determine what appropriate replacements are
>> needed. Normally, I would look at CPU performance, amount of RAM and disk
>> speeds (HDD vs SSD vs NVMe makes a huge difference).
>> Hope that helps!
>> Donal
>> On Wed, 9 Sep 2020 at 02:00, RMG <reikogoodwin at gmail.com> wrote:
>>> Hello QGIS users on Macs,
>>> I would like advice on purchasing a new Mac. My Mac is 5 years old and
>>> cannot handle heavy-duty QGIS procedures. I process many satellite images
>>> and some vector files with 30 m grids have millions of features, for
>>> example. To process anything is taking too long. I know there has been a
>>> discussion on ARMS hardware, but that seems a few years away. So right now,
>>> what would you recommend? I plan to partition the hard drive to handle
>>> ArcGIS as well. I do not think I can afford a dream machine like Mac Pro,
>>> though. Is a Mac mini something that you guys use and recommend?
>>> Best wishes,
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200909/8e79bee5/attachment.html>
