[Qgis-user] Report Layout strange behaviour with photos
Håvard Tveite havard.tveite at nmbu.no
Mon Sep 14 13:52:03 PDT 2020
Including photos / images in reports is covered by the documentation.
See:
https://docs.qgis.org/testing/en/docs/user_manual/print_composer/create_reports.html#including-pictures-in-a-report
It worked for me.
It should now also be possible to use images stored in a BLOB field.
Håvard
On 14.09.2020 18:20, Bernd Vogelgesang wrote:
> Hi there,
> I'm really eager to finally figure out how to create a photo
> documentation with QGIS.
> Everything needed is prepared and in place. I have overview coverages of
> plots with sub-plot over an aerial image. The maps are nicely produced
> to a report as groups. On each overview, the belonging sub-plots follow
> as individual maps.
> Now I would like to show pictures taken on the sub-plots.
> First issue: I add a new group photo-points and as field I select the
> referencing field for the sub-plot. Edit body, add picture frame. When
> setting the full file path for the images (stored as field "photo" in
> the point file, generated with "Import geotagged photos") there is only
> a red cross shown, and the selection in the dialog jumps from raster to
> svg. On export as pdf, there is a warning "Picture source is missing or
> corrupt".
> I redid this several times, to no avail, but once in a sudden, a preview
> image was shown, though I did not change the slightest thing in the
> settings. I swear!
> Second issue: Now that it finally accepted the path, exporting the
> report now produced a page for each picture under each sub-plot, instead
> of filtering those which actually fit there (and how it does with the
> sub-plots within the plots!)
> Has anyone an idea what might be wrong here. Documentation on this
> matter or examples are unfortunatly nonexistent.
> Linux Mint, 3.14.1
> Cheers,
> Bernd
> Qgis-user mailing list
