[Qgis-user] Report Layout strange behaviour with photos
Andreas Neumann
a.neumann at carto.net
Mon Sep 14 23:30:49 PDT 2020
Hi Bernd,
The report functionality definitely needs some love. There is a great
base now, but it needs to improve.
Would you volunteer to collect missing things regarding reports in a QEP
and then help organize a crowd-funding? Even if you can't fund this
yourself, it would help a lot to come up with a sound proposal /
specification, that some interested developer can submit a quote and we
can look around for funders.
There are quite a few successful examples in the past where someone who
missed a functionality in QGIS but couln't finance it came up with a
sound proposal and then we could find a developer and funders based on
that initiative.
Or you could organize this as a joint effort - e.g. through the german
QGIS user group.
Greetings,
Andreas
On 2020-09-14 23:09, Bernd Vogelgesang wrote:
> On 14.09.20 22:30, Håvard Tveite wrote:
>> Including photos / images in reports is covered by the documentation.
>> See:
>> https://docs.qgis.org/testing/en/docs/user_manual/print_composer/create_reports.html#including-pictures-in-a-report
>> It worked for me.
>> It should now also be possible to use images stored in a BLOB field.
>> Håvard
> Thanx for answering. Indeed there is something about adding photos, but
> actually this version of the doc is somehow not showing up in google
> searches:
> Furthermore, I did not have the problem of having to construct a path to
> the image. The full path is already in the data (from the nice toolbox
> function for geotagged images). The report just did't eat the path.
> After dozend and dozends of attemps, QGIS somehow seemed to give up on
> refusing them, and now miraculously is accepting the path.
> The problem, that all images where repeatedly showing in all section got
> solved too. In the level up for the subplots, I had to use the field
> unique for each subplot and not that for the plot, as I wrongly assumed.
> Having it set wrongly didn't influence the correct print of the plots
> and then their subplots, but had influence on the follwing photos. Pfuh,
> the logic behind, how the report "knows "what to print in lower levels
> is actually not really obvious, It seems to figure this out on its own.
> So, seems I get it working.
> Major flaws:
> There is only the possibility to select an existing field for a layer in
> report groups. So the data has to be prepared for each and every
> possible usage beforehand. Having the possibilty to use expressions here
> would be phantastic. So now, when you find out that you had not the
> right variables for your job in the data, you have to stop working on
> the report and fumble the stuff into the attributes. I worked around
> this problem by setting up a nice model to prepare my data, but not
> everyone has the knowledge to do so.
> Found no way to add sections within the "tree" or to move anything. Once
> you laid out a design and forgot a title page or mid-sections, you seem
> to have to restart from scratch. No way to manipulate it later.
> Found no way so far to add page numbers.
> All in all. Spent 2 days now on this 30 page report and I hope I will
> remember next time how to glue things together.
> This could be a really powerful tool for lazy people having to do boring
> reports frequently. So far, no time was gained, and I had to use extra
> doses of alcohol not to give up.;)
> Hopefully developers will give it a little more love some day to make it
> a bit smoother, then it will really rock!
> On 14.09.2020 18:20, Bernd Vogelgesang wrote: Hi there,
> I'm really eager to finally figure out how to create a photo
> documentation with QGIS.
> Everything needed is prepared and in place. I have overview coverages of
> plots with sub-plot over an aerial image. The maps are nicely produced
> to a report as groups. On each overview, the belonging sub-plots follow
> as individual maps.
> Now I would like to show pictures taken on the sub-plots.
> First issue: I add a new group photo-points and as field I select the
> referencing field for the sub-plot. Edit body, add picture frame. When
> setting the full file path for the images (stored as field "photo" in
> the point file, generated with "Import geotagged photos") there is only
> a red cross shown, and the selection in the dialog jumps from raster to
> svg. On export as pdf, there is a warning "Picture source is missing or
> corrupt".
> I redid this several times, to no avail, but once in a sudden, a preview
> image was shown, though I did not change the slightest thing in the
> settings. I swear!
> Second issue: Now that it finally accepted the path, exporting the
> report now produced a page for each picture under each sub-plot, instead
> of filtering those which actually fit there (and how it does with the
> sub-plots within the plots!)
> Has anyone an idea what might be wrong here. Documentation on this
> matter or examples are unfortunatly nonexistent.
> Linux Mint, 3.14.1
> Cheers,
> Bernd
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200915/33e39e30/attachment.html>
