[Qgis-user] Report Layout strange behaviour with photos
Bernd Vogelgesang bernd.vogelgesang at gmx.de
Tue Sep 15 02:17:05 PDT 2020
Hi Andreas,
hope I did not sound too negative. For sure I would like to help in some
way. I give money in nearly every crowdfunding project, though I even
don't need most functionalities there.
Around the report function, there is quite a sounding silence in the
lists and the web, so I assume that few people use it, or feel too
stupid to ask cause they don't get it to work properly.
What I already tried, was to collect issues on github for the Report
But already there the problems begin: There is not a label for it (only
a general "Print Layout") and report is a very common word)
This may be intended as the reporting seems to be the younger brother of
the Atlas, but makes it not easier ;)
Before I would be able to create a QEP, I would need someone to explain
me the parts in Report that I maybe simply do not understand.
So, count me in (at least a bit ;) )
Bernd
On 15.09.20 08:30, Andreas Neumann wrote:
> Hi Bernd,
> The report functionality definitely needs some love. There is a great
> base now, but it needs to improve.
> Would you volunteer to collect missing things regarding reports in a QEP
> and then help organize a crowd-funding? Even if you can't fund this
> yourself, it would help a lot to come up with a sound proposal /
> specification, that some interested developer can submit a quote and we
> can look around for funders.
> There are quite a few successful examples in the past where someone who
> missed a functionality in QGIS but couln't finance it came up with a
> sound proposal and then we could find a developer and funders based on
> that initiative.
> Or you could organize this as a joint effort - e.g. through the german
> QGIS user group.
> Greetings,
> Andreas
> On 2020-09-14 23:09, Bernd Vogelgesang wrote:
>> On 14.09.20 22:30, Håvard Tveite wrote:
>>> Including photos / images in reports is covered by the documentation.
>>> See:
>>> https://docs.qgis.org/testing/en/docs/user_manual/print_composer/create_reports.html#including-pictures-in-a-report
>>> It worked for me.
>>> It should now also be possible to use images stored in a BLOB field.
>>> Håvard
>> Thanx for answering. Indeed there is something about adding photos, but
>> actually this version of the doc is somehow not showing up in google
>> searches:
>> Furthermore, I did not have the problem of having to construct a path to
>> the image. The full path is already in the data (from the nice toolbox
>> function for geotagged images). The report just did't eat the path.
>> After dozend and dozends of attemps, QGIS somehow seemed to give up on
>> refusing them, and now miraculously is accepting the path.
>> The problem, that all images where repeatedly showing in all section got
>> solved too. In the level up for the subplots, I had to use the field
>> unique for each subplot and not that for the plot, as I wrongly assumed.
>> Having it set wrongly didn't influence the correct print of the plots
>> and then their subplots, but had influence on the follwing photos. Pfuh,
>> the logic behind, how the report "knows "what to print in lower levels
>> is actually not really obvious, It seems to figure this out on its own.
>> So, seems I get it working.
>> Major flaws:
>> There is only the possibility to select an existing field for a layer in
>> report groups. So the data has to be prepared for each and every
>> possible usage beforehand. Having the possibilty to use expressions here
>> would be phantastic. So now, when you find out that you had not the
>> right variables for your job in the data, you have to stop working on
>> the report and fumble the stuff into the attributes. I worked around
>> this problem by setting up a nice model to prepare my data, but not
>> everyone has the knowledge to do so.
>> Found no way to add sections within the "tree" or to move anything. Once
>> you laid out a design and forgot a title page or mid-sections, you seem
>> to have to restart from scratch. No way to manipulate it later.
>> Found no way so far to add page numbers.
>> All in all. Spent 2 days now on this 30 page report and I hope I will
>> remember next time how to glue things together.
>> This could be a really powerful tool for lazy people having to do boring
>> reports frequently. So far, no time was gained, and I had to use extra
>> doses of alcohol not to give up.;)
>> Hopefully developers will give it a little more love some day to make it
>> a bit smoother, then it will really rock!
>> On 14.09.2020 18:20, Bernd Vogelgesang wrote: Hi there,
>> I'm really eager to finally figure out how to create a photo
>> documentation with QGIS.
>> Everything needed is prepared and in place. I have overview coverages of
>> plots with sub-plot over an aerial image. The maps are nicely produced
>> to a report as groups. On each overview, the belonging sub-plots follow
>> as individual maps.
>> Now I would like to show pictures taken on the sub-plots.
>> First issue: I add a new group photo-points and as field I select the
>> referencing field for the sub-plot. Edit body, add picture frame. When
>> setting the full file path for the images (stored as field "photo" in
>> the point file, generated with "Import geotagged photos") there is only
>> a red cross shown, and the selection in the dialog jumps from raster to
>> svg. On export as pdf, there is a warning "Picture source is missing or
>> corrupt".
>> I redid this several times, to no avail, but once in a sudden, a preview
>> image was shown, though I did not change the slightest thing in the
>> settings. I swear!
>> Second issue: Now that it finally accepted the path, exporting the
>> report now produced a page for each picture under each sub-plot, instead
>> of filtering those which actually fit there (and how it does with the
>> sub-plots within the plots!)
>> Has anyone an idea what might be wrong here. Documentation on this
>> matter or examples are unfortunatly nonexistent.
>> Linux Mint, 3.14.1
>> Cheers,
>> Bernd
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
