[Qgis-user] Axes
Charles Dixon-Paver
charles at kartoza.com
Thu Aug 26 12:37:29 PDT 2021
I think the best approach will greatly depend on your input data structure
and situation, but I should think it certainly is possible.
In the processing toolbox, there is a GRASS tool called v.voronoi.skeleton
which is pretty effective at producing single centerlines from polygons. If
what you want is not achievable with a single tool, the modeler will allow
you to chain processing steps to achieve that outcome, likely in a much
more effective manner than in the article you linked to. There may also be
community built processing models available on GitHub or GIS stack
exchange which might already do this for you. We are hoping to get more
solutions on the https://plugins.qgis.org/models/ platform so that this
type of content is more discoverable in future.
I hope that's at least enough to help you get started.
Regards
On Thu, 26 Aug 2021 at 19:05, Marcio Midon <marciomidon at gmail.com> wrote:
> hi Charles,
> It's something like this:
> https://support.esri.com/en/technical-article/000012414
> But i just work with QGIS and Linux,
> Thanks for all,
> Best Regards,
> Marcio Midon.
> Em 26/08/2021 08:44, Charles Dixon-Paver escreveu:
> Hi there,
> I think it may be a bit unclear exactly what your objective is. Perhaps
> attaching an illustration of some sort would help the community better
> understand the problem so that we can assist with a solution.
> Regards
> On Thu, 26 Aug 2021 at 02:06, Marcio Midon <marciomidon at gmail.com> wrote:
>> Hello colleagues,
>> I need to generate in QGIS street axes from a block face and that these
>> axes cross for two meters.
>> It's possible?
>> Best regards,
>> *Márcio Midon*
>> Arquiteto e Urbanista UFPel
>> Especialista Geoprocessamento UFPR
>> Mestre Geomática UFSM
>> Doutorando Geografia UFSM
>> Tel 53 3305 7075 | Cel 53 98100 2020
>> SKYPE marcio_midon
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Cordialmente,
> *Márcio Midon*
> SKYPE marcio_midon
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210826/997075a0/attachment.html>
